Max II cargo basket install
+ Reply to Thread
Results 1 to 2 of 2
Thread: Max II cargo basket install
  1. #1
    Hello, Looking for some info on how you folks have mounted your cargo baskets to the back of your Max II over the top of the engine compartment. I'm looking to have my basket on a hinge so I'm still able to easily access the engine. Thanks.
  2. #2
    Join Date
    Jul 2015
    Location
    Nebraska
    Posts
    7
    I just put 2 2x4s on their end and screwed that to the cover. Then screws through the carrier into the wood.
    It doesn't support a lot of weight since the engine cover is plastic and tends to bend when its warm out.
    Im looking to build a stand that comes off the sides where the stock roll cage would mount that would have pins for easy removal.
    Im sure the MAX IV & II are different... but here is one on ebay currently:
    https://www.ebay.com/i/303102449516?...SABEgJ0nvD_BwE
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
