I am looking for a set of Attex Thunderchief Sprockets. I need them for a racer, please let me know if you have some. Thanks.
Sprockets needed
Same here. I've got a big box of used sprockets, but they all start to look the same after a while. Maybe between the two of us, Dave and I can come up with a complete set for you.Originally posted by countrybumpkin View PostIf you can give me the # of teeth and the spacing from the bolt hole to the sprocket, I will see what I have.Stuck in the seventies- not in the swamp.
Thanks guys, I will have to go out tomorrow and measure the sprockets on my other machine because I don't have the correct ones to measure. I know the ones on my racer are 440 Thunderchief sprockets. That is what i am looking for. I will check them out and send the measurements in the morning. The sprockets are pretty much all that is left for my A stock racer. I didn't realize the sprockets that I had weren't going to work until recently.Originally posted by Don View PostSame here. I've got a big box of used sprockets, but they all start to look the same after a while. Maybe between the two of us, Dave and I can come up with a complete set for you."Racing is life. Anything that happens before or after is just waiting."
I measured the sprockets and this is what I am getting. (Everything is in inches)
Standing in front of the machine.
Front Right 2-1/4
Middle Right 7/8 to the small sprocket and 2-3/4 to the bigger sprocket
Right Rear 1-3/4
Left Front 2-1/2
Middle Left ¾ to the small sprocket and ¾ to the bigger sprocket
Left Rear 3-3/16
The two middle sprockets are the most important, if I can find those I can make it work.
Small sprocket 20 teeth
Large sprocket 26 teeth
Thanks guys!"Racing is life. Anything that happens before or after is just waiting."
Found two centers. Silver one measures right but would need a beveled washer welded over one hole. Rusty one measures 3/4" from center of hole to side of small sprocket and 3 5/8" to side of big sprocket. I suppose you could grind the weld off the one side of the sprocket and move it over.Attached Files
Sounds like a winner. What do you need from me?Originally posted by countrybumpkin View PostFound two centers. Silver one measures right but would need a beveled washer welded over one hole. Rusty one measures 3/4" from center of hole to side of small sprocket and 3 5/8" to side of big sprocket. I suppose you could grind the weld off the one side of the sprocket and move it over."Racing is life. Anything that happens before or after is just waiting."
I think I have some fronts. I'll check tomorrow afternoon. I thought I had all my old thunderchief sprockets but I could not find them. I'll check on the fronts I saw when you first posted. They are either thunderchief or superchief not sure.sigpic
