Harbor Freight sent me a coupon book in July that had a coupon to get the 22hp Predator engine for $599. Even though I still have a lot to do before I'm ready for the engine, the coupon was only good until July 31st, so I could pass that up for the Hustler I'm rebuilding. Now that I have the engine, though, I'm looking through the manual and can't seem to find anything about a charging system. So now my mind is working....
I plan on adding a custom-built trolling motor system to my Hustler with 2 motors and joystick control (building everything myself) so I'm going to need a decent amount of power.
If I wanted to add a small alternator to the engine, how would be the best way? Slip a pulley on the shaft between the clutch (a comet 780) and the engine? If I do that, and the drive shaft is no longer long enough, would it be safe to create a drive shaft extension out of 1" stock with a hole down the center and just use a longer bolt to hold everything on?
And yes, I know that anything I do is going to change the alignment of the clutches. I have to make a new engine mount anyway, so I'd like to tackle this now rather than down the line.
I'm open to any thoughts, recommendations, comments, accusations of insanity, etc. lol
