Hi Guys
Merry Xmas to all, I was out on my Max II yesterday, and today checked chains, has i was getting a funny sound like a chain rubbing on metal ect, one chain was a bit lose front drive wheel, when i press the adjusters, one setting it reaaly lose and the next is tight. very little play in chain, any ideas? also i have another Max II had a bent axle, another member got it best he could straight with a very slight wobble on axle, I fitted it ran it with wheels off the ground and the outer bearing is moving in it flange, will this cause problems to outer bearing or damage anything else?
On the other side of the Max, I have play in the outer middle bearing, how hard are these to change? any tips? had a pig of a time with the removing the bent axle.
Richie
