23 hp vanguard acting funny
+ Reply to Thread
Results 1 to 5 of 5
Thread: 23 hp vanguard acting funny
  1. #1
    Join Date
    Jul 2011
    Location
    Butler Mo.
    Posts
    19
    Man I have a problem with a 23 hp v-twin vanguard. It is surging at idle and I had changed fuel filter and plugs when i took off air cleaner it seems to run smoother and also when I take out the fuel filter it helps. I do have some smoke coming from the black vent hose that hooks to the air cleaner. I adjusted the governor and that helped a little but now I"m stumped. any help would be great.
  2. #2
    Join Date
    Mar 2012
    Location
    South Shore MA.
    Posts
    157
    I feel your pain , I am dealing with my own demonic 23hp V-twin ... except I have messed up the governor setting and of late had little time to try to fix it ... Do you have the adjustable Carburetor? What I know about small engines you could put on a head of a pin so I have been surfing the net for solutions ...it is out there from simple fixes of cleaning the carb to complete over hauls and modifies... I can only wish you the best and hope you fix a fix ....
    Bill G.
  3. #3
    Join Date
    Mar 2011
    Location
    Colonial Heights, VA
    Posts
    497
    how long has it been since you last cleaned your carb? I would start there if you have already replaced plugs and fuel filter
  4. #4
    Join Date
    Aug 2012
    Location
    Mississippi
    Posts
    126
    disassemble that carb and soak it in some chem dip for a couple of days, blow/clean out all the passages, reassemble with a genuine Briggs rebuild kit and your problems will be solved.
    Thomas
    94 MAX IV, 16 Vanguard, Aqua Torques, 1 1/4" wheel spacers
  5. #5
    Join Date
    Jul 2011
    Location
    Butler Mo.
    Posts
    19
    My repair manual will be here monday and that is when I will get midevil on this thing.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
