After over 5 days and over 800+ views and no response, I gambled today, and used my above checklist and attempted replacing belt. It was not easy, mostly because of my age and portly belly, but I...
Again, late to the dance, but when I saw this thread, I remembered that I had seen a 'PDF' for SN lookup's. While I could not find the same on a web search, I found that I had downloaded and saved...
You can install a low pressure electric fuel pump (use only a 2-3lb pressure pump) to help. Unless its bitterly cold you will not have to touch the choke. I rig mine in addition to the vacuum pump,...
I'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
After over 5 days and over 800+ views and no...
hipowerone 10-05-2024, 10:27 PM
