Materials: 1 CO2 Paintball tank (I used a 24 ...
How-to articles relating to tires and wheels utilized on your amphibious 6x6 or 8x8 ATV
How to build a CO2 Tire Inflator
Created by:
evil8x8
- 0 comments
I am sure there are many ways this could have been built but I just wanted something to seat beads and inflate tires on my ATVs in the field and I didn't want to spend a whole lot of money. The CO2 Paintball Universal Fill Adapter is the key part. It screws on the top of any paintball tank and when the knob is turned, a pin pushes down on the release pin of the paintball tank and releases the pressure out of the threaded hole on the side.
Materials: 1 CO2 Paintball tank (I used a 24 ... -
Created by:
Fixing those unfixable sidewalls
Created by:
pheagy
- 0 comments
I wonder if any of you guys have the problems I have when it comes to fixing my tires. I figured I'd show you some of what I've done to make those tires run when the tire man says he can't do anything. Both of these methods rely on the use of some kind of tire sealant after the repair. Most brands work well, currently I'm using slime and I'm very pleased with it. For holes that are caused by a puncture of some sort and are to big for plugs to hold, I have used carriage bolts with washers with great ...
Created by:
balloon tire valve stem replacement
Created by:
Amphiman1
- 0 comments
Here's a long over due secret.. how to replace balloon tire valve stems.. 1) break off old stem.(thats the easy part..) 2) get a package of the smaller valve stems(any auto parts store carries them ,usually.. # 413 's?) 3) this may take practice.. you need a used pair of pliars, a dull screw driver, and some quality dish soap..(full strength..) 4) slowly ..attempt to put the bottom end into the tiny hole of the wheel,after sand paper cleaning around the hole and ... -
Created by:
There are no articles in this category.
Categories
article_tags
- 4x4 (1)
- 6x6 (2)
- amphibious (4)
- attex (1)
- atv (3)
- buyers (1)
- buying (1)
- download (2)
- gotcha (1)
- guide (1)
- hustler (1)
- industries (1)
- inspection (1)
- manual (3)
- max (1)
- operator (2)
- operators (1)
- owner (2)
- owners (2)
- parts (4)
- purchase (1)
- recreatives (1)
- superchief (1)
- truck (1)
- utv (1)
Latest Articles
by Amphiman1Here's a long over due secret.. how to replace balloon tire valve stems.. 1) break off old stem.(thats the easy part..) 2) get a package of the smaller valve stems(any auto parts store carries them ,usually.. # 413 's?) 3) this may take practice.. you need a used pair of pliars, a dull screw driver, and some quality dish soap..(full strength..) 4) slowly ..attempt to put the bottom end into the tiny hole of the wheel,after sand paper cleaning around the hole and ...
Channel: Tires / Wheels
02-11-2010, 11:12 PM -
by evil8x8I am sure there are many ways this could have been built but I just wanted something to seat beads and inflate tires on my ATVs in the field and I didn't want to spend a whole lot of money. The CO2 Paintball Universal Fill Adapter is the key part. It screws on the top of any paintball tank and when the knob is turned, a pin pushes down on the release pin of the paintball tank and releases the pressure out of the threaded hole on the side.
Materials: 1 CO2 Paintball tank (I used a 24 ...-
02-11-2010, 11:08 PM -
by pheagyI wonder if any of you guys have the problems I have when it comes to fixing my tires. I figured I'd show you some of what I've done to make those tires run when the tire man says he can't do anything. Both of these methods rely on the use of some kind of tire sealant after the repair. Most brands work well, currently I'm using slime and I'm very pleased with it. For holes that are caused by a puncture of some sort and are to big for plugs to hold, I have used carriage bolts with washers with great ...
02-11-2010, 11:04 PM -
