How-to articles for everything related to 6x6 and 8x8 ATVs. From completely rebuilding the skid steer T20 transmission to removing oxidation from your six wheeler's body it is all here as a step-by-step guide!
 Easy T-20 split shifter Guide-
					Created by: Rabbit929
- Published: 10-31-2016, 03:36 PM
- 0 comments
 Easy T-20 split shifter GuideThis is on a 94 Max II 18hp Briggs and Stratton You will need: Grinder Welder I got all my parts from tractor supply. Parts List: -1/2x1x2 inch steel bushing (anything will work but the inside diameter needs to be 1/2in) -1/2in steel pipe (hollow or solid, you only need about a foot) -shift knob of your choosing, I haven't found a matching one yet. -2 1/2in inside diameter spacers/washers (the think ones) Start by cutting the cross shaft. I cut mine an inch and a half from the ...
					Created by:
 Pressure lubricating a Max throttle cable-
					Created by: MAX IV Mark
- 0 comments
 Pressure lubricating a Max throttle cableEvery time I go to start my Max in winter the throttle cable is frozen. I have a heated throttle cable but it takes about 20 min idling to get it free. I figured a good way to lube, purge the water and keep it from freezing.
 I took a condiment squeeze bottle I had laying around and filled it with antifreeze. You could put your own mixture in it if you are worried about using antifreeze.
 Removed the engine cover to get at the cable end. This engine is the 29 Kawasaki...
					Created by:
 T-20 Assembly video-
					Created by:  George George
- Published: 09-26-2012, 04:59 PM
- 0 comments
 T-20 Assembly videoThis video walks you through the assembly of a Borg Warner Skid Steer T20 transmission.
					Created by:
 Rework an Early T20 to Accept Thrust Washers-
					Created by: whipper-ag
- Published: 02-18-2012, 10:18 PM
- 0 comments
 Rework an Early T20 to Accept Thrust WashersI'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
 Whipper    :6x6burnou  t:... :6x6burnou  t:...
					Created by:
 Adjusting Chains and Jackshafts on a Max II-
					Created by: Mike
- Published: 03-14-2011, 08:05 PM
- 0 comments
 Adjusting Chains and Jackshafts on a Max IIFor anyone new to six wheelers, this is a short video showing you how to adjust the chains in a Max II. There are eight chains that need to be adjusted. The chains between the front and middle axles and the chains between the rear and middle axles are tightened using the ratcheting chain adjusters. The ones in the front are adjusted by pushing the adjusters down. The ones in the rear are adjusted by pulling the adjusters up. The remaining four chains are adjusted by moving the jackshafts. ...
					Created by:
 Repairing a Grooved Axle-
					Created by: Planter Bob
- Published: 09-15-2010, 08:07 PM
- 0 comments
 Repairing a Grooved AxleDo you have a grooved axle and a shallow wallet? Well, here's the ticket for solving the problem without burning up the Visa card.
 Repairing a grooved axle on the cheap: 1. Remove the axle. 2. Clamp it firmly in a smooth-jawed vice, with the groove about 6" from the jaws of the vice. 3. Using a wire brush in a 4" grinder, clean all the area in and around the groove, making it free of rust and gunk. Use a flat file gently on any high spots. 4. Use paper towels and wipe down the...
					Created by:
 Upgrade your Argo Conquest bearings to HDI-
					Created by: Rock Doctor
- Published: 06-07-2010, 09:05 PM
- 0 comments
 Upgrade your Argo Conquest bearings to HDIWell, I finally got this little project started . I think everything is going to work out good, but there is still some testing to do. I ran into a couple little issues, but nothing that can't be dealt with.
I have to say here that I'm NOT SURE if this will work with ALL Conquests. I have noted that some ... . I think everything is going to work out good, but there is still some testing to do. I ran into a couple little issues, but nothing that can't be dealt with.
					Created by:
 Bronco Seat for your Six Wheeler-
					Created by: racerone3
- Published: 04-13-2010, 09:57 PM
- 0 comments
 Bronco Seat for your Six Wheeleri've needed to redo the seats in my wild wolf for as long as i've had it. the seat back was the original and shot, and the bottom was something i had quickly thrown together. last week after months of my son begging me to take him for a ride in my old bronco, i finally got the back seat down from the rafters of my shop and bolted it in. later that night it dawned on me that it would make a pretty good seat for the Wolf. i checked with the place i'd gotten my seat covers form when i built the bronco...
					Created by:
 Max II T20 Split Shift Modification Video-
					Created by: LarryW
- Published: 03-22-2010, 08:47 PM
- 0 comments
 Max II T20 Split Shift Modification VideoThis is a how-to video for making a split shifter for your T20. While I did the modification on my Max II, the same principals will apply on most Borg Warner Skid Steer T20 transmissions regardless of which ATV it is in. Instead of having one lever that controls shifting of both sides this mod will let you shift each side of the transmission independently allowing you to counter rotate. I even got to scare myself a little.
					Created by:
 Used ATV Buyer's Guide-
					Created by: Mike
- 0 comments
 Used ATV Buyer's GuideGeneral - Purchasing your first six wheeler can be exciting and it is something that many of us remember well; Seeing it for the first time, the test drive, towing it home, taking it for a spin around the yard and realizing how quickly you can tear up the grass. But it can also be an intimidating process especially if you are not purchasing new. For some, a new six wheeler is simply out of the question. Whether it is financial concerns or simply that the six wheeler you are looking for is no...
					Created by:
There are no articles in this category.
						Categories
	article_tags
	Latest Articles
	by Rabbit929This is on a 94 Max II 18hp Briggs and Stratton You will need: Grinder Welder I got all my parts from tractor supply. Parts List: -1/2x1x2 inch steel bushing (anything will work but the inside diameter needs to be 1/2in) -1/2in steel pipe (hollow or solid, you only need about a foot) -shift knob of your choosing, I haven't found a matching one yet. -2 1/2in inside diameter spacers/washers (the think ones) Start by cutting the cross shaft. I cut mine an inch and a half from the ...-
							Channel: Transmissions
 10-31-2016, 05:36 PM
	by MAX IV MarkEvery time I go to start my Max in winter the throttle cable is frozen. I have a heated throttle cable but it takes about 20 min idling to get it free. I figured a good way to lube, purge the water and keep it from freezing.
 Removed the engine cover to get at the cable end. This engine is the 29 Kawasaki...-
							Channel: Engines
 01-01-2014, 12:32 AM
	by GeorgeThis video walks you through the assembly of a Borg Warner Skid Steer T20 transmission.
 09-26-2012, 06:59 PM
	by whipper-agI'm sure that some of you have opened up some Early T-20's & found them FUBAR. Once the gears start digging into the drum face, it doesn't take long to ruin the bearings, wear the bands down & cause excessive wear on the ring gear. Fortunately, all is not lost. In most cases, it can be modified to add the fiber thrust washers which are now used in the Late Model T-20's. Here's a video how to do it.
 Whipper    :6x6burnou  t:... :6x6burnou  t:...-
 02-18-2012, 11:18 PM
	by MikeFor anyone new to six wheelers, this is a short video showing you how to adjust the chains in a Max II. There are eight chains that need to be adjusted. The chains between the front and middle axles and the chains between the rear and middle axles are tightened using the ratcheting chain adjusters. The ones in the front are adjusted by pushing the adjusters down. The ones in the rear are adjusted by pulling the adjusters up. The remaining four chains are adjusted by moving the jackshafts. ...-
							Channel: General
 03-14-2011, 11:05 PM
	by Planter BobDo you have a grooved axle and a shallow wallet? Well, here's the ticket for solving the problem without burning up the Visa card.
 Repairing a grooved axle on the cheap: 1. Remove the axle. 2. Clamp it firmly in a smooth-jawed vice, with the groove about 6" from the jaws of the vice. 3. Using a wire brush in a 4" grinder, clean all the area in and around the groove, making it free of rust and gunk. Use a flat file gently on any high spots. 4. Use paper towels and wipe down the...-
							Channel: General
 09-15-2010, 09:07 PM
